pressuretrol settings
Jim_42
Member Posts: 4
What is the correct pressuretrol setting ,cut-in cut out for a 120,000 input -96,000 output on a small residential gas fired steam system home with 6 radiators.
as low as possible...
less than 1.5 to 2 psi. Why do you ask?0 -
Cut it at .5 psi
and cut out at 1.5 psi if you have a pressuretrol. And that's only because it's the lowest possible setting on a standard pressuretrol.Retired and loving it.0 -
Thanks for the responce, it seems boiler is cycling on and off more this winter after the local gas company tech who who inspected and made adjustments ( which they do for free as part of service) this leads me to believe i have other problems to check out and elimate one at a time.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 100 Chimneys & Flues
- 5.6K Gas Heating
- 101 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
