flow rates of PEX
Tony_8
Member Posts: 608
as the same nominal size copper tubing ? I guess my question is actually more related to head resistance. Seems it would be considerably less for PEX, considering the lack of fittings for bends.
Need to know soon.
TIA,
Tony
Need to know soon.
TIA,
Tony
Actually....
just played with Siggy's HDS a bit and it seems that the flow rate for 150' of 3/4 copper with 10 - 90's would still be much greater than 3/4 pex with no 90's. Now, PAP seems to be much closer to the copper.
If you don't have the HDS... get it... it's well worth the bucks!!!
JMHO Floyd0 -
thanks Floyd
Tube to tube
The id of this type L copper is larger than 3/4" pex, by quite a bit. I imagine that's where the flow difference comes in.
hot rod
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.5K THE MAIN WALL
- 54 Biomass
- 97 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
