Coil additions
don_9
Member Posts: 395
it will increase your senible capacity,but decrease
your latent capacity.
We are talking the indoor coil correct? If so add a txv and
you made need to make a fan adjustment when the humidity is
high.
high.
Coil Additions
Please advise if it is inappropiate or would result in premature system failure if I took a 9 year old 1.5 ton AC unit and added a new 2 ton coil to the system. I was told that coil additions should be exact or it would result in premature failure or a freezing of the unit.0
- 129 Chimneys & Flues
- 122 Geothermal
