Ridgid Pro Press
For the advice and pics.I can't wait to pipe my first boiler with it!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=100&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • John Felciano
    John Felciano Member Posts: 411
    Ridgid Pro Press
    I broke down and bought myself a Christmas present(Ridgid Pro Press),now if the UPS driver can get it here before the holiday.
    Any pointers from the guys useing the Pro press?
  • heatboy
    heatboy Member Posts: 1,468
    ProPress!
    Felcie,
    Keep your fingers out of the way (g)!
    hb
    KeepTo Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    My advice....
    Quote:Mr. Milne...."You gotta let someone else use it you know!". I've taught the course to the rest of the class, and find it in my truck the most. I don't know if they're just stubborn, or too proud to view the future as a sucess.
    I find it an outstanding tool . There are very few places it won't fit, and proper planning leads to almost zero places. I just did a "boiler in a closet" install and used it for all things that would have taken too much time with a torch.(1 1/4 inch feeds and returns in this space would have lead to CO poisoning in a day or two).
    Get used to the pricing of doing a job with it ! The time is cut manyfold, but the price of the fittings is substantially more. Just a warning. The other thing I found at first was availability of fittings. This has become far less noticable in the last few months alone. A good supply house is now stocking piles of fittings. A GREAT supply house is finding all the silly little tees and reducers that we use everyday, and stocking them also.
    In my humble opinion, this is a great tool , and a big step forward in the industry. Make sure you tell your insurance company that you use it ! It may lead to a decrease in your premiums, knowing you aren't bringing FIRE into a dwelling , as often as you once did. Enjoy it ! Chris. Wanted to attach a good photo, but can't figure out how
  • heatboy
    OK, seriously...........
    The biggest hurdle is inventory, as Chris said. You need a good wholesaler on your side, but you still have to invest in stock yourself.
    I have yet to have a leak, but I can see it will be a pain if I do because you are taking out sections of piping, not just a fitting like soldering.
    On the positive side, labor is cut at least five fold when you take prep and clean-up in to consideration. Might even be ten fold. The labor savings more than make up for the price difference in fittings, which, in my opinion, until you get to 1 1/4" and above, really isn't that much from soldered fitting, especially if you use long sweep solder fittings.
    You will still your trusty B-tank, since the ProPress ball valves require fittings on both side. Can add up to substantial money to use the valves.
    All-in-all, I'll never go back to soldering.
    hb
  • ScottMP
    ScottMP Member Posts: 5,882
    Hows this Chris ?
    By the way maybe the reason the others don't use it more is , They can't pry it out of your hands :).
    This tool is way cool..
    Scott
  • J.C.A._3
    Yeah,
    That's the one I wanted to show. You'll be teaching me how on Mon. morning ....right? Chris
  • P. Smith
    P. Smith Member Posts: 20
    How does it work?
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    Check out this link...
    http://www.ridgid.com/propresssystem/
    ME
