Steam Main Vents From Home Depot
Tom_22
Tom_22 Member Posts: 108
I got a bunch of these steam main vents from Home Depot. The packaging indicates they're model A883 from Durst in Mountainside, NJ, but it turns out Durst is only a distributor. The vents are made in Asia. Someone at Durst, after scratching his head for a while, told me they're equal to a Hoffman 45. Duh, a Hoffman 45 is a convector vent. I don't think thats what they are.
Does anyone know what the capacity of these vents are or how they compare to a Hoffman 4A or a Groton #1?
While were on the subject, does anyone know how the venting capacity of the Hoffman 4A and the Groton #1 compare? Are they equals?
Thanks for any info.
    Steamhead Member Posts: 18,753
    Those vents
    have a capacity roughly the same as the Hoffman #4A, which vents about 0.4 cubic feet per minute (CFM) of air at 2 ounces.
    The Gorton #1 or Hoffman #75 will vent about 1.4 CFM at 2 ounces.
    And the monster Gorton #2 will vent about 5.5 CFM at 2 ounces.
    That said, I wouldn't bother. Those cheapo vents don't last very long. Spend the money and get the good ones.
    To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"
    Consulting
  • Duane
    Duane Member Posts: 17
    Durst...or whistle while you work
    I just took back a bag of those Durst vents. They not only vent slowly (I don't believe they are intended as main vents), but are noisy, with whistling regardless of the setting. several also failed to close reliably, they would noisily shudder open and closed instead of closing positively.
    A waste of money IMO. I got no response from Durst whatsoever.
  • James W.Stamo
    James W.Stamo Member Posts: 28
    Home Depot garbage
    Most of Home Depot stuff is garbage nowdays, steam valves is the best example.
  • Fred P
    Fred P Member Posts: 77
    I have those home depot vents
    they are cheap enough to buy for testing purposes and then throw away and put on real vents like gortons of hoffman
