W-Mc 368 steam to water
nick z.
Member Posts: 157
I know This isn't the best thing to do but, these people hava no heat and no money.
Someone gave them a 368 Steam boiler we need to use for water. There are 2 tappings on the bottom of boiler(front&back).Can I use the one in the back for the return or must it return in the front? Reason is back was used for steam and the front has a plug in it that looks like it wants no part of coming out. Thanx, Nick
Back tap is fine.
Shouldnt be a problem at all.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Some WM boilers
The smaller WM boilers I see for steam are dual designed for hot water. If you go to a wholesaler or perhaps WM website they should have a installation guide you could follow for the hot water trim.0 -
plugs
any plug can be removed. simply cut it out. or heat & unscrew it. if some one put it in ,you can take it out.0 -
W/M 68 series.....
Instruction sheet showed this rear tapping as an optional(hot water) return. The front is probably a better place for complete circulation through the boiler, but the rear will work. Chris0 -
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
