Steam conversion
Riles_3
Riles_3 Member Posts: 60
Wet Heads:
HELP NEEDED!
I am helping on a job that has taken a twist.
It started as a Hot Water system for a new three story addition in which they are installing Runtal radiators with a Munchkin Boiler (L/P).
The existing house is Steam with an oil fired boiler (2.25 GPH Nozzle). I was just called. I have not calculated the radiation. I do not know much about the steam system, as I have not been in the existing house yet.
Now they ask if they can put in a larger L/P boiler to replace the oil fired boiler.
What additional info is required to evaluate?
Is this possible, if so I welcome details/ideas.
If so would all the existing radiators need to be replaced.
Thanks,
"Riles"
Jeff Riley
Thos. Somerville Co.
Chantilly, VA
