Oil Boilers
Jimmy Gillies
Member Posts: 250
I thought you guys may want to have a look at the small oil boilers we fit here in Scotland, also there is some smart towel rails that this company supply.
www.heatingworld.com
Have a look at the small Grandee fitted in the kitchen cabinet.
Regards.
Jimmy
Regards.
Jimmy
I've seen some nice US Kero heaters
from HTP here in the states. Strange why products like these are not marketed more in the US as a high efficency alternative to the 90%+ gas condensing boilers out there.
I know here on Long Island, while a big market for #2 home heating oil. I don't think I've ever seen a Kerosene delivery truck. Prices for K-1 at filling stations seem to be around the same as #2. Does K-1 have lower or higher heat ouput per gal then #2? Are there any more specs on these units?0 -
btu output
k1 has lower btu,s per gal tnan #20 -
They look like nice small units. They also look almost the same as the Vitodens/Veissmann boilers (gas). Are they about the same as the Monitors oil boilers?
Steve0 -
UK Oil boilers
Thanks to all who had a look at my post & the boilers.
These boilers, like most UK domestic boilers use Kero and are very clean burning.
We install lots of the wall mounted type - they lift the Kero up to about 8ft, so the plastic oil tanks sit on a base in the garden.
We use indirect hot water heaters, steel panel radiators or radiant under floor heating.
Thanks again & a Merry Christmas to you all.
Jimmy Gillies (Scotland)0 -
K1
Joe
Here on Long Island, kero is used a lot in mobile homes in these tiny oil-fired scorched air units (Miller is a popular one). I was told it is because of the very small nozzle sizes ( around 0.50 gph) and the fact that the storage tanks are always outside. Being outside #2 oil would get so thick in winter that @ 0.50 gph there'd be too many no-heat calls. Kero is supposed to flow much better.
There's an oil company (Manna?) in Amityville that delivered K1 to the mobile home parks there in a stubby oil truck (small tight access roads in the parks).
Patchogue Phil
- 129 Chimneys & Flues
- 122 Geothermal
