Main vent problem?
dk
Member Posts: 11
Hi, there,
Now I am confused, about the main vent, I saw my house have two 2" pipes strain up to the roof with one hoffman angle #40 air vent connected each, one is in the bathroom, one is in the dinningroom, questions:
1. What are they?
2. how to tell which one is for short main supply, and which
one is for long main supply(assuming they are main vent).
3. If I like to replace them with Gortan vent, which one
should I chose, #2? or?
Thank you all in advance.
dk
1. What are they?
dk
Are these
just 2-inch risers with no radiators connected to them?
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
Steaamhead,
No radiators connected to them,,, just the pipes(risers) go to the roof, the #40 is about 1 foot away from the roof.
dk0 -
Hoffmann #40
is just a non adjustable radiator vent. As the pipe is just capped and not connected to any radiators, it is just a long radiator itself. Do they heat up quick enough to heat the rooms they pass through? are there also radiators in the D.R. and bath?
If not, perhaps Gorton D radiator vents would work, a #1 or a #2 would need a reducing reducing ell and a 1/8" nipple to fit the main vent to the tapping in the pipe.
What do you have for main vents in the cellar at the end of the horizontal mains? This would be a good place for Gorton #1's or #2's if the current vents aren't up to snuff, so the steam gets to the inlets of the radiators, and to the riser pipes you describe, fast.0 -
Also
how long are those steam mains, and what pipe size?
Consulting0 -
Steamhead,
The main supply pipes are about 40' in the front, and 20 ft in the rear, 3" diam size, and I took a look there were no main vents at each side that people described 15'' around the end ell?( also a questions now, is it possible that I can add them in the future?). Thanks.
dk0 -
You can use
two Gorton #1 or Hoffman #75 vents on the long main, and just one on the short one. BTW, was that 3-inches the outside diameter of the pipe?
Consulting0 -
main vents problem
Steamhead,
Thanks for the reply, the main pipe outside diam is 3", but the two risers diam are 2", and how could I tell which is suppose to be long and short? because the two risers just wnet through from the first floor one in the bathroom and one is dinning room, should I assum the one in bathroom is short one? since it is more close to the rear end? Thank you!
dk0 -
#2 and #1
Scrook,
Thanks, I also got two #D gorton vents now last weekend, and I would see how it goes, I like to use the #2 on long main( Steamhead suggeted use 2 #1 on the main, but there is just one port there) and #1 on short if it is ok. Thank you all.
dk0 -
Put 2 Gorton # D on the risers
I have replaced 2 #40 hoffman with 2 #D gorton vents at the risers pipe which are branch up from the main supply( both about five feet from the boiler) all the way to roof, I noticed that the two riser pipes gets hot fastter, and the all radiators heat up much faster too( the burning cycle around 13- 20 min shorter), I would like to ask if I still need to add main vents on the two main supply? is it the main vents must vertical up or can they branch out? Thanks in advance!0 -
Are those risers
fed from the very ends of the steam mains?
Consulting0 -
About in the middle
Thoses risers fed from the middle, the one from long main supply is about 5-6 feet away from the boiler then branch out to the wall and sraight up through to roof without radiators, the one from short pretty much the same is about 8 feet away from the boiler. By the way, I remesuare the pipes, I believe the mains are 2 1/4" and the the risers go to the roof are 1 3/4". Thank you very much.0 -
Hoffman #75 got huge vent holes and cost $$$.
Hello:
I looked at one of those Hoffman 75 Vents at the plumbing supply the other day. Dang, those puppies have three or four huge vent holes in them. I got a Home Depot special deluxe main air vent (the only one they sell: it has a 3/4" connection and costs about $7.00) on my basement main (2" x 60') and the vent hole on that looks about the size of a number 6 radiator vent.
The 75 is so much more huge than what I have on there now it scares me. How much faster will such a vent make the steam come down my main? Would two of those bad boys be recommended for me also? They were charging $57.00 each for them also. Not cheap, no siree. Whats the approximate payback time on saved fuel, or maybe you factor in reduced wear and tear on the boiler and whole system????
How about the Hoffman 4A main vent. How much 2" pipe are they good to handle? I forgot to look at one of those and ask the price.
Happy New Year to all and the best,
Jake0 -
Gorton #1 Looks Nowhere Near the Size of A Hoffman 75
Hi, Is a Gorton #1 about equal in venting rate to a Hoffman 75? I doubt it by looking at them. The H75 is about three times as big overall with about 5 to 10 times the orifice area. An H75 also costs five times as much as a Gorton #1.
Tom0 -
A Gorton #2 is equal in venting to about three #1s
>>>>like to use the #2 on long main( Steamhead) suggeted use 2 #1 on the main, but there is just one port there and #1 on short if it is ok.
...I think... I have to find my notes. You can manifold the tap on the long main to put in two #1s.
Tom
PS: Does anyone know the venting rate of the Gortons in cubic inches/min. at .5 psi?
Unscrew the cap
from the top of a #75 and you will see that the orifice underneath is similar to the Gorton #1.
If you blow thru them, you will feel the same thing.
Then try a Gorton #2. You'll see why I like this vent so much.
The Hoffman #4A is so small that I only use it on very short mains... about 15 feet or so of 2-inch pipe, or less. I remove many more of these vents than I install. I suppose some techs install them because they're relatively cheap, but when I see one at the end of a 60-foot main it makes me wonder why they bothered with it? Sure, a Gorton #2 costs more but in this case it's the right part for the job.
Consulting0 -
Yes you can
I do that all the time to install two main vents when there's only one tee. Works fine.
The Gorton #2 actually equals four Gorton #1 or Hoffman #75 vents.
I don't have the CIM ratings at 1/2 PSI. But I find that with proper venting, you can fill a steam main with steam at 2 ounces or less. Steam at this miniscule pressure is very gentle and very quick.
Consulting0
- 120 Geothermal
- 394 Solar
