Tekmar controls
Derek Brazier
Member Posts: 16
Does anyone know why they require a 120v feed ?, when the relays they contain are dry, and the system pump for instance has to have it's own feed. I would have thought the electronics they contain would only need a low voltage supply. What am I missing?
Convenience
The older Tkemar controls ran off low voltage. The new ones now run off line voltage. I belive it is simple more convenient to wire, I certainly find it so.
Boilerpro0 -
I bet they have not had as many fried controls sent back to the factory, since they changed it.
Steve0 -
It took years
to get them to build 120 Volt controls! Much more versatile for installers. No more seperate transformers.
I think the UL gets more involved when a control contains 120 volt components, hense the delay in getting them to market.
hot rod
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
funny you should mention that....
I just changed out an older control and when I was done wiring the new one I was like, hmmmmmm......something's not right here....good thing I actually read the instructions
Phil0
- 129 Chimneys & Flues
- 122 Geothermal
