Zones with constant circulation
hr
Member Posts: 6,106
for this well planed and diagramed approch. Looks a lot like our friend Dan Peels systems :) Copy and open this link.
hot rod
http://www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,113669,00.html
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
hot rod
Thanks for
pointing out this article. It's very timely since I was trying to relate to my hydronics class why constant circulation was a desireable thing to design into a system. Sometimes I have to learn to modulate the amount of information I inject into their brains. Hows that for an analogy? Heewack! :)WW
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Pulsed flow modulation
and at least one counter flow spiral loop in every floor, thanks Hotrod
Dan
Nice module
Dan. I just recently learned that 3 way is available in sweat connections with unions. Make for quick, easy replacement. Take the other back to the shop to clean and rebuild.
A certain beauty in simplicity. Years ago, probably 10 or more, I used a few tekmar pulse width modulation controls. You merely pulsed a basic on/ off zone valve to mix high temperature into the radiant zone.
Makes you wonder why we have gotten so complicated, and expensive with mixing controls. How accurate is accurate enough
hot rod
- 129 Chimneys & Flues
- 122 Geothermal
