Header question
Paul Mitchell
Member Posts: 266
Just a question as far as header size goes. What if the manufacturer calls for a 3" header and you put in a 4" header. I would guess that a larger header is not bad. I am bidding a job that has an existing four inch header with 2 3" risers from an old boiler. I may be able to connect my 2 2" risers to this old header. Any comments would be appreciated.
Paul
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=280&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
Paul
Your header size is going to depend on flow rate of total system 2" pipe with can pass 50 gpm which turns to be approx 500,000 btus at a 20 F temp drop
And if it's steam
no problem. Bigger is slower and better.
Noel0 -
Sorry
it is steam...thanks guys
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
