Members of the drop header club
The piping looks like the crew does steam every day . Most heating guys who don't work with it would be amazed on how hard it is to pipe a steam boiler right , while trying to keep all the pipes level and straight . And with 2 steam takeoffs to the system , and the return piping done all in black steel , you did a hell of a job .
It doesn't look like too much fun piping the boiler on the right side . Where was this install , in a cavern ? See any stalactites or bats down there ?
Excellent work Chris , Lou and Scott . The end product looks like something out of a steam manual .
  • ScottMP
    ScottMP Member Posts: 5,882
    We joined the club
    Or as Chris says He joined the club.
    This is the most recent Steam job we've done and of course we had to follow our Wallie brothers :). Actually Chris and I we wating for a steam job just to do one.
    This is a Burnham IN8LNC. I sized it to the Radiation and then added a little for piping pick up. Chris and our new helper Lou ripped out the old and piped in the new.
    Great work Chris.
    Scott
  • ScottMP
    Resize photos
    I posted that from the new laptop and hav'nt figured out how to resize them with the new program. So its back to the old machine for some proper viewing.
    By the way, the customer can't believe how quite and quick the new system is. The insualtion goes on next week after another skim.
    Scott
  • ScottMP
    New feeder
    Have any of you used this feeder ?
    Its a Hydrolevel vxt 24 with a digital display for gallons used. Nice feature for servicing.
    By the way the work in the background was NOT our work. Whats up with compresion ball valves for a New installation ?
    Scott
  • heatboy
    heatboy Member Posts: 1,468
    Geat work, Scott.
    I love seeing a well piped steamer. Wish I knew how to do steam!
    I also love the decor!
    hb
  • Pretty
    I expect nothing less if you guys are piping it!
    Great work!
    Noel
  • ScottMP
    Chris
    Is the guy with the pipe dope on his hands.
    The compliments are all his.
    Scott
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Thanks Noel.....
    I wish I knew about this when I worked in Marblehead. It would have saved me a lifetime of Not having the room I needed.
    Things change, and the more I learn, the less I know. I call it the "happy juxtiposition". If I ain't moving forward, I'm going backwards, and that isn't right.
    Thanks for the great comments. Chris
  • David Sutton_3
    David Sutton_3 Member Posts: 160
    Sweet job Scott welcome to the club
    well you would not know thats the frist one.looks like you been doin it forever. sure is nice to see the pride in the work. my complements to you and your crew!!
  • Mad Dog
    Mad Dog Member Posts: 2,595
    Outstanding JCA and Scott!!!!!!!
    Very impressive and I'm very happy to see cast Iron fittings - gives that exalted look. On the return, I always install a gate valve or at least a ball valve as the wet return rises up in to the Hartford loop to facilitate complete flushing of the wet returns. I would put it where that union is. Tremendous job though. Any relation to Helen "GURLEY" Brown? Mad Dog
  • ScottMP
    Naaahhh
    Just an eye Doctor.
    Thanks for the nice remarks. As I said Chris is hefting the wrenchs.
    Scott
  • J.C.A._3
    After....
    All the copper work, and using the ProPress tool I've done lately, I thought that my body would be aching from using the pipe wrenches for the amount of time it took.
    Surprisingly, I didn't hurt as much as I thought it would.
    I, and the homeowners like the results. Thanks to all Wallies for the drive to try something different. ( I would have said new...but we all know that we're just finding that the DEADMEN knew it first) Chris
  • very nice piping
    it actually makes it easier to do the header dropping it, dont you think..drier steam, easier,nicer install,,thats a win-win every time..
  • Nice work Chris...
    > This is
    > just to do one.
    > Great work Chris.
    > Scott
    > _A
    > HREF="http://www.heatinghelp.com/getListed.cfm?id=
    > 237&Step=30"_To Learn More About This Contractor,
    > Contractor"_/A_
    as usual you do an excellent job. Say isn't that the Rock of Gibralter in that picture. How did that get into mix???
  • J.C.A._3
    Thanks Tim.
    Fortunately, the rock came with the basement. It has been both, a blessing and a curse. Sometimes it helps, other times it's in the way, know what I mean? Chris
  • Dave_16
    Dave_16 Member Posts: 51
    VXT feeder
    I've used them a number of times, I think they are most beneficial on systems with underground returns, They tell you how much water is being fed into the boiler and they come with a chart to give you an idea of how much make-up water is allowable given the BTU rating of the boiler.
    Frank
  • Paul_11
    Paul_11 Member Posts: 210
    Wouldn't a three inch header make drier steam?
    Nice looking job for sure!
    I agree with you though on the isolation valve on the wet return. You didn't mention it, but I assume that you also install a tee with a drain valve on the wet return side of that valve so you can drain the return and keep steaming on the boiler side.
    I don't mean to be critical, but, with two 2" risers and two 2" take offs I would have make the header 3". Of course I'm not sure what the boiler btu load is. Perhaps it is so small it doesn't make any difference. I would be real curious what the velocity of the steam going through that one two inch header is. Usually, we just increase to three inch at the second riser and go back to 2" after the 3" drop to the equalizer.
    Paul Shay
    Since 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
    NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
    A REAL GOOD PLUMBER, INC
    NYC LMP: 1307
    O:212-505-1837
    M:917-939-0593
    Steamhead Member Posts: 18,753
    IN7-12 piping diagram
    does call for a 3-inch header. That said, I can't tell for sure from the photo what size the header is...........
    Consulting
