Boiler Pic's
S Davis
S Davis Member Posts: 491
This is our latest boiler install,7000sq.ft. Radiant floor system in seattle Wa.
  • Weezbo
    Weezbo Member Posts: 6,232
    clearly. on the beam:)
    low water. secondary high limit. Pump away .on and on :)
    straight and simlpe.:)
    so maint is the pleasure side of the cruise:)
  • Climate Creator
    Climate Creator Member Posts: 103
    Nice
    I like the joints nice and clean. Very nice job, one question, why did you dip the bypass like a heat trap and not go straight accross? It looks nice as it is I just wondered if the was a function to it? Is that a tempering valve? It looks like a reg gate?
    VERY nice,
    RICH
  • S Davis
    Differential Presure By-Pass
    The valve all the way on the left is a differential Presure By-Pass it Keeps your velocity from getting to high when only small zones call for heat.
    The Heat trap helps keep heat from migrating from the high temp loop to the floor loop.
    S Davis
