insulating shower stall
rodr
Member Posts: 20
Hello
I have just finished installing pex with wirsbo heat transfer plates on a shower wall.I was wondering what insulation to use.I have some foil faced insulation i was thinking of using but was not sure about having a vapor barrior behind the shower.Do any of you have any thoughts?The walls are standard 2x4 construction.
thanks
Rod
thanks
Rod
- 129 Chimneys & Flues
- 122 Geothermal
