Cast Iron Radiator Conservancy
Climate Creator
Member Posts: 103
Dan, (or anyone else) is there anyway I can use your EDR book to look up the btus of a given C.I. Rad and give it an equivalent baseboard fin tube value, eg I was trying to explain to someone that removing the freestanding rads is not an energy conserving move. Is there a formula I can use on the job to say to a customer...yeah if you remove this X-size radiator youll need xyz feet of fin tube to replace it. I dont think I should have to do a heat loss to figure that general equiv. Any Ideas?
Thanks,
Rich
Thanks,
Rich
Sure ,from my rad pad
170 degree water going into rad = 150 btu per sq ft edr
180 " " " " = 170 " " " "
190 " ' " ' = 190 " " " "
You can calculate from there.
If you had a radiator with 5sq ft @ 180 degree water you would have 800 btu's dived by 580 btu's per ft for (average) baseboard to give your equivalent baseboard length.
Regards,
Robert0 -
Thanks, did you
see my post, with your drips installed?
Rich0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
