Radiant Wall
Where can I get good info on different radiant wall applications? Would Ayr-foil with tubes installed in front of it work good? 120deg? thanks
  • Daniel Schlicher
    Daniel Schlicher Member Posts: 2
    Radiant Wall
  • hr
    hr Member Posts: 6,106
    What info do you need?
    It's basically a floor turned on edge!
    The same R-value math applies for loss calcs. They can run a bit warmer surface temperatures (higher output) as generally folks don't walk on them :)
    Some of the radiant manufactures have design help in their manuals, for wall and ceiling applications.
    Always, always start with a room by room heat loss calc. Then build the "panel assembly" be it walls ceilings, or floors around the design numbers. Happy heating.
    hot rod
  • Ted_8
    Ted_8 Member Posts: 31
    Transfer
    The transfer factor changes from 2 btu/sqft to I believe 1.6 btu/sqft. Check with your manufacturer.
    Ted
