setting aquastat differential
R. Kalia
R. Kalia Member Posts: 349
I have a very old (27-30 yrs) Weil-McLain with no documentation. There is a dial inside to set the water temperature. Inspired by things I've read, I want to increase the temperature difference between the on and off settings, in order to see if this will make a difference to gas use by increasing cycle times. (The furnace is very oversized, so letting the water cool a bit more won't affect its ability to heat the house on very cold days.)
Now you haven't seen this particular aquastat so maybe this is not a reasonable question...can anyone suggest where I might look to try to find a way to adjust the differential?
I am afraid I'll learn here that it's probably fixed. if so, what is it likely to be fixed at? Or to ask it another way, what's a typical differential used in boilers? I don't have a thermometer with probe.
Many thanks,
  • Earthfire
    Earthfire Member Posts: 543
    30 yr old control
    its working , don't mess with it. Look at it say "nice control", and enjoy the feeling in your wallet that says you haven't had to replace it
  • steve_38
    steve_38 Member Posts: 74
    oh yeah
    I would definitley take earthfires advice
    don't tuch! nicely said earthfire!
  • Boilerpro_3
    Boilerpro_3 Member Posts: 1,231
    It's not the 30 year old controls I worry about
    They seem to just keeep going, it's the newer aquastats that seem to be failing. Just replaced a 3 year old honeywell on a friends boiler. Got a Penn- Johnson a couple years ago that was 70F out of calibration right out of the box. Productivity....Ha with no quality control!
    Boilerpro
  • hr
    hr Member Posts: 6,106
    An additional control
    could be added and leave that one in place as a high limit control. tekmar makes various boiler controls, Heatimer and a few others.
    I tend to trust thermistor based sensors more than the older style capilary styles.
    Maybe it't that Pemex, Mexician oil that they are filler with these days, that causes such wide temperature response and/ or inconsistencies!
    hot rod
  • mellow
    mellow Member Posts: 19
    burning too much
    The reason for doing this adjustment to the control would be to save on gas, right? The control adjustment on a boiler this old could not save that much money. The boiler and piping make the biggest savings. This control change can leave you with a cold house and higher gas bills. Old boilers are not designed the same as new boilers are.
