please explain this product
R. Kalia
Member Posts: 349
<a href="http://intellidynellc.com/res_hw.htm">
Does this make sense? Does is work? Will the water be too cold for a cast-iron boiler? Sorry, newbie questions.
Does this make sense? Does it work? Will the water be too cold for a cast-iron boiler? Sorry, newbie questions.0 -
Just realized that this is the same product as the
Becket heatmanager
My questions are still relevant though.
I don't understand if it is getting heat load feedback by measuring the return water temperature---it doesn't quite say that.
And if it can expand the deadband, why doesn't it just lower the max temp instead? (I realize this would not reduce short-cycling.)
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
