oil burner motors
Mike321
Member Posts: 1
How can you tell if an oil burner motor is good or not?
Sometimes you can find it in thermal overload or stuck and has to spun then you know its no good. But besides quessing is there a way to check it out?
Try this
Link
http://www.oiltechtalk.com/Just For Tek's/burner-motor.htm
It will tell you all you need to know about oil burner motors except psc style.
Regards
Robert0 -
Try an amp draw test
If the amp draw is excessive, the bearings or fuel unit may be blown.
I use this a lot in training:
http://www.leeson.com/literature/tech_info/pdf/tech2400_troubleshooting.pdf0
- 120 Geothermal
- 169 Indoor-Air Quality
