Accellerated Watts?
JimGPE_3
JimGPE_3 Member Posts: 240
Okay, here's how you know I'm a nerd....
KwH is more accurately given as kWh, since the W stands for Watts, a fellow's name.
And it stands for kilo Watt hours, not kilo Watts per hour.
I had to get that off my chest.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Believe this is correct usage
    My peak load is 14 kilowatts per hour and my monthly usage is 284 kilowatt hours.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,724
    Noted
    and fixed. Thanks!
    Retired and loving it.
  • JimGPE_3
    I hate to belabor this, but....
    kW=3413 Btu/hr. Thus, both kW and Btu/hr are an energy RATE, similar to miles per hour. You pay for the total energy used, which is the rate times time, or BTU's, or kWH.
    kW/Hr would convert to (Btu/hr)/hr or Btu/(hour squared) which is not a unit used too often.
  • JimGPE_3
    Um, sorta....
    The kWh part is fixed, but the explanation should read kiloWatt hours not kiloWatts per hour. The "hours" part goes in the numerator. Delete the word "per."
    Thanks for the clarification...
    ...now I see said the blind man! That "per" be in there already!
