becket burner
Gary
Member Posts: 29
Its a one pipe system , is the fuel supost to drip out of the bleed valve or run in a steady stream?
Whats the best way to bleed a becket burner of fuel oil
Thank you for your time0 -
Perhaps you meant
air entrained in the oil?
If two-pipe, just hit the reset button once or twice.
A filter should be in there somewhere. Filters have bleeders on top that would get some air out. This assumes the oil level in the tank is ABOVE the bleed point. If not, air will be sucked into the bleeder and make it worse!
If a one-pipe and the oil is below the burner - take a deep breath and ask someone about a Tiger Loop.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
