steam question
steve_6
Member Posts: 243
How far below the normal water line does a loop seal have to be? thanks in advance, steve
Do You mean ?
Like, for a Hartford Loop? About 2" below minimum water line for the tee and as close to floor as I can. But I am not sure what you mean0 -
not the hartford
The connection where the drips from the main and the dry return connect together before they drop into the wet return.0 -
I'd make it
at least a foot if you can. This is a Vapor system, right?
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"Baltimore, MD, USA
Consulting0 -
vapor it is
thanks . Is their a reason the loop seal crosses over to connect the drip to the dry return? Why wouldn't they have dropped both of them straight down into the wet return?0
- 125 Chimneys & Flues
