12 VDC Thermostats
mph
mph Member Posts: 77
I'm finishing a heating system on a boat and the owner doesn't like the look of the standard Honeywell or WR bi-metal thermostats. For obvious reasons we can't use mercury thermostats. I need something either small and unobtrusive or, better yet, something with a remote sensor. We don't have 24 VAC, so tekmar is out.
Any suggestions?
Jeff
  • Dave H_2
    Dave H_2 Member Posts: 625
    Surface-Stat II
    Jeff-
    We have a stat the we use for mostly radiant floor systems but it can be used for air sensing also.
    The power can be 120VAC, 24VAC, or 12VDC.
    It is not a great looking control, but the sensor can be placed in the room (up to 500' away) and it will read from 32F to 160F.
    Part number 4028, take a look at the attached bottom right corner.
    Dave Holdorf
    Taco, Inc
  • jwade55_3
    jwade55_3 Member Posts: 166
    I've used these before
    and with some nice results. Remote sensor capable, keeps people from playing with temps. They are also available in heat/cool.
    J
  • jwade55_3
    jeez
    guess I should read a bit more before I type 12VDC, sorry.
