For those with PB systems
eric_9
eric_9 Member Posts: 15
Hi those of you who have PB systems that have lasted over 12 years, what are the other components of your system (ie. boiler, expansion tank, pump, heat exhanger) and how have you maintained it? Thanks
  • Ruthe  Jubinville
    Ruthe Jubinville Member Posts: 67
    PB
    You don't want to know. It shouldn't work but it does. Jerry
  • Einsiedler
    Einsiedler Member Posts: 61
    for the most part
    for the most part, we've had to isolate the PB portion of the system with a heat exchanger with non ferrous components on the PB side of things.
    Once the PB has been separated from the ferrous part of the system, I've seen less component replacements.
    regards,
    Einsiedler
  • John MacGregor_3
    John MacGregor_3 Member Posts: 31
    PB
    Check my post earlier on pb pipe. Our shop boiler is a Glowcore(#@%*!) that we bought back from an unhappy customer. It works fine for us. I think any non-ferrous boiler would work well. We used a standard Amtrol pressure tank and put No-Burst anti freeze in it.
