Testing F & T Traps
Tony_6
Member Posts: 2
What is the best way to test a F & T Trap when they were installed without valves or a test tee?
testing traps
Without a test tee or a union on the discharge side, temperature or a stethescope is about the only way. IF you've got a temperature tester with bulb, strap in on the discharge. You'll get a temp rise when the trap dumps. The stethescope will allow you to actually hear the trap dump.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0
- 125 Chimneys & Flues
