Re: Cycling Timing and Comfort
Fred P
Fred P Member Posts: 77
talked about on here? Im a little confused. I see that some are discussing that they cycle theyre steamer once an hour or 3 times an hour with a digital thermostat.
How do you control the amount of cycling per hour? If the thermostat is not satisified ,doesnt your steamer continue to run and shut off on pressure- I do assume you build up pressure during your steaming?
