cpvc
Stuart_3
Member Posts: 2
PLease tell me whether or not cpvc can be used to supply
hot water baseboard heaters run off a gas boiler in a single-family residence.
Stuart
Stuart
I've seen it
In China....
This was on a district heating setup so the temps are fairly low by comparison to our rad standards. Enjoy....Dan
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
I'd ask the ....
manufact.They will tell you their testing and liability extent.kpc
that
ball valve is ot cpvc, it's straight pvc.
the problem is that pcv can't handle the high temps of hot water, cpvc can. not sure about from a boiler, but I have seen lots of it coming directly off water heaters set at the highest temp (150??).
Kevin is right, contact the manufacturer, they can tell you better than anyone.0
