Question for Dan
Boiler Guy
Member Posts: 585
When using primary secondary pumping does the boiler loop have to be connected into the bottom of a horizontal only or can it be connected with the proper spacing in a vertical riser?
BTW Did you read about my Knuckle head special in the Are we having fun yet post last week?
Thanks Tim
Thanks Tim
Temperture in furnest will not go up
The water in the furnest is not getting hot enoght I even turn the setting up on the water control and it will not go above 160 the rest of the units in house are working fine.I try going as high as 220 aqnd it will not move0 -
Either way works, Tim.
And, yes, I did. Thanks.Retired and loving it.0
- 125 Chimneys & Flues
