steel fin base
kid plumber_2
Member Posts: 6
on a one pipe steam system , when in stalling steel fin baseboard do you need to install a return or can you hook it up the same as a radiator
I don't understand
you must go in and must must go out. I must be missing something.
Gary
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
does steel fin baseboard need a return0 -
if you have more than four running feet you will probably need a return .try it and find out!! sometimes steam works when it should notbut not very often. if you are a do it yourselfer you got nothin' but time.0
