reillo in the barn
joe_31
Member Posts: 24
need some help have 2 kerr furnaces with riello burners set 175# pump pressure 2 pipe system, i have already removed the elements inside the oil filters the owner only starts these units on weekends for auctions cold oil problems he must push reset several times to pick up oil and fire needs ideas on keeping oil warm, burner pumps warm [they pull in fresh od air into burner box barn gets outside cold all week] had idea of light bulb inside box, on timer along with 50/50 kero/oil mix and electric heat tape on line and setting up tigeer loop. make any sense? all ideas from the colder areas are welcome this job in harrisburg area thanks
Joe, try these.................
www.Nationalmagnetic.com They make a tank heater that is automatic on at 40 degrees, goes in tank , priced right too. Hope this helps John@Reliable0 -
Thank you and
check this out too!
http://disc.server.com/discussion.cgi?disc=24736;article=34712;title=OIL TECH TALK
George Lanthier0 -
riello in the barn
To let you know from the Albany, NY area. To solve that lock out promblem is total do to the cold oil (or 50/50)You diffinatly have to go to K1 and I would also install the Tiger Loop. Sounds like a bandaid, but the Riello pump has zero tolerance to real cold fuel. The Tiger loop will build some heat to the fuel by friction of recirculation. if you do this take another cumbustion test, you will have to make minor adjustments. Have learned 2 things Riello burners do not like cold oil and especially not 2 line systems with cold oil. Get a real laugh, call the riello rep and he will tell you "first time i have heard of this and you guy`s are the only one having this promblem". GOOD LUCK.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
