Triange Tube Combo Heater
Patrick Powers
I have used the f-35 oil fired in a couple of applications nice piece of equipment quiet and pleanty of hot water. I don't know how it would be for radiant but the deliver plenty of btu's and fired a number of different nozzles for oil.
Info on triangle tube combo heater
I'm looking for opinions on Triangle Tube Comination Heater, specifically the Delta Performance PG series used to provide heating and water for radiant system and domestic hot water. I'm open to any opinions you all would have on these units good or bad. And why you would or wouldn't use them. And what you would use instead if you weren't using this unit. We have a radiant system. Tubes in our basement concrete, and suspended tube under our first floor. Obviously we want efficiency and are currently running on propane as fuel. Thank you.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
