Cast Iron Baseboard for one pipe steam
Drod
Member Posts: 59
room, I have a small sunporch with a very large radiator (with a vent that vents very slowly as the radiator heats very well). To open up more space in the small room, I'm considering replacing the big radiator with cast iron baseboard. I have a 3 foot long baseboard in another part of my home, but for this room I'd probably want 10-12 feet. I've heard that for one pipe steam, it's recommended that baseboard be kept short. What I'm wondering is: could I do a "two pipe" set up to the one, long baseboard. Since the room is right above the boiler room, it would be doable from a physical standpoint. But, is it okay? Any suggestions?
Yes,
vent the end and drain the end into a wet return, or back into the steam main, using a loop seal. It's all in The Lost Art of Steam Heating (see Books & More).Retired and loving it.0 -
how short is short
with one pipe and no drip return for baseboard radiator?0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
