That's what I like
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
about this business; never a dull moment, always something new.
This is something I can't figure out and neither can any of my suppliers; so I need a little help from the heating clan.
This is a radiant heating job with a Taco zone valve controller; this controller operates manifold actuators at a remote (about 20' away) manifold. On a call for heat, 24 volts gets to the actuators, but they don't open and the end switch doesn't close.
Some notes:
- The actuators get warm, but not as warm as a properly working actuator.
- There are 6 actuators on the manifold and they all act the same way.
- It's not a problem with the thermostats; I jumpered the wires.
- Actuators are 3 VA ea.; 6 of them adds up to 18 VA and the transformer is 40 VA. But just to make sure, I took 4 actuators off the grid and they acted the same.
- I spoke to my Taco and Rehau rep's. and they said there haven't been any problems with their products.
I plan to go back and try those actuators with different transformer; after that, I'll be stumped.
Any ideas?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
Some notes:
Any ideas?
Have you checked amperage?
i.e. ammeter in series with valve(s) when supplied with current?
A poor or loose connection will show proper voltage.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
