Water Temp flow relationship
mark_20
Member Posts: 9
Can anyone tell me the mathematical relationship between water temperature and flow rate in a radiant floor system After doing the calculations i have manifold that has one loop that needs 115 degree supply and another that needs 95 degree water (mistake in initial design). I will supply the manifold with 115 degree water. I want the btu's to remain the same on the 95 degree loop so i need to cut the flow. If I raise the calculated necessary supply temp by 20 degrees (95 to 115) how much should I decrease the necesaary calculate flow rate.
- 87.4K THE MAIN WALL
