New system design help
Eric_11
Member Posts: 12
I have an existing home without a central heating system. It is located on the water in Narragansett RI and it is a 4 level house. (Very Odd design). I have spoken to several heating contractors in my area and most of them just want to install one type of system (whichever is their specialty). I would personally like to install a radiant floor system, but think because of its shape/size/style it requires some sort of a mixed system. Presently, 2 of the floors are used as living areas and would like to finish the other two floors in the next couple of years.
Who can I contact to design a system that can be installed immediately for 2 levels, yet leave room for expansion in he future?
Radiant Flooring
Radiant flooring is the most comfortable heating system around. Forced air is aweful, baseboard is better, in-floor is best. As for installing in sections, the main work to be done is the mechanical system.
Baseboard requires a higher supply temperature than staple-up in floor heating(tubing stapled under the floor in joist bays, sometimes with aluminum radiator panels to disburse heat), which also requires a higher supply temperature than slab in-floor (tube stapled to floor and light weight gypcrete poured over it to create a radiant mass.) Whatever combination of these types of heat you would prefer, will determine what installation work must be done initially to the mech. system piping. The staple up manifold would be seperate from a slab manifold, which would be different from a regular baseboard supply and return off the boiler.
If you choose in-floor (gypcrete is preferred in most cases) plan for the extra zones by having the installer add additional taps to the in floor manifold and valve them off, so that at a later date you can add the zone valve, thermostat, infloor tubing, and have heat with minimal fuss. The simplest, and therefore most cost-effective systems have one type of heat, though I must admit to filling garage walls with two injection manifolds(1 staple up, 1 slab), and regular baseboard piping, and indirect water heater piping on occasion. Hope this helps.0 -
Eric
I live in Hope Valley just a stone throw away. I'ds be more than happy to help you with your design questions.0 -
Check out
the Find a Professional section of this site. Lots of serious talent there.Retired and loving it.0
- 129 Chimneys & Flues
- 122 Geothermal
