steam main question
steve_6
Member Posts: 243
I have a new install coming up. My question is the existing mains are tee'd together where the boiler feeds them. The tee is "not" bullheaded, it's turned on end. It's a 3"x 3" x 2" tee and the mains it connects are 2", and 3" and is feed through the bottom with 3". Is there a disadvantage to leaving this as is, or should I separate it? thanks in advance,,, Steve
That should work OK
Personally I prefer a separate header takeoff for each main, but the setup you describe should be fine.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
advantages
what are the advantages to separating them? Is it steam velocity, or friction loss through the tee? thanks again!!!0 -
velocity
by slowing it down AT the header, more water would be left behind.
Noel0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
