Low water cutoff
Float chambers need to be cleaned annually. You could dry-fire and split the sections if it were to stick in the OTHER position.
You're lucky, today.
Noel
  • adambuild
    adambuild Member Posts: 425
    Low water cutoff!?
    Have a client with a residential Utica steam boiler. Low water cutoff is telling the water feeder to fill the boiler when there is clearly too much water in the boiler! Any ideas?
