Can dirty steam water cuase hammer by....
Steve_55
Steve_55 Member Posts: 30
by building up sludge in the pipes and preventing proper retun?
If so, how might it best be cleaned?
It is a two pipe, vacum-vapor system and the hammer is at the early part of the cycle.
    Steamhead Member Posts: 18,290
    It can
    Clean that boiler real well, and see if it quiets down. If it doesn't, isolate the area of the banging and check for bad pitch or a clogged return.
    Consulting
  • Steve_55
    Thank you Steam Head
    Thank you Steam Head.
    Is there a better way for my Technician to clean out a two-pipe, vacum vapor system (i.e., I hear there is a cleaner that stays in the system, versus another type that needs to be flushed out, etc).
    Also, are there any downsides/risks to be carful with -- I hope my Tech know his business, but not always so I like to double check.
    I knowe the excat pipe/section of pipe that is banging. It is not a return pipe, but right off one of the branches of the main steam pipe.
    Thank you for any further advise!
  • Travis G.
    Travis G. Member Posts: 22
    cleaners
    Is this an old or new boiler. I wouldnt put any thing in a boiler. Some boiler manf. will void the warrenty on the boiler if any chemicals are put in it. Also some chemicals can and will plug up vents and I think it might cause short cycleing in the steam boilers. Steam head is the best person to ask. I am always on here learning something new from his advice. And I use it in the feild. I am a note book junkie! Good luck
  • Ken_8
    Ken_8 Member Posts: 1,640
    Pressure?
    You may want to see if the pressure is within the correct parameters.
    A vapor system should never go much above a pound - tops! If the pressure is over that, water may be backing out of the return and blocking the vent piping.
    This would cause banging/hammer.
