Triangle Tube Combo Heater--Have you had Success?
George_11
Member Posts: 11
What do you think of them if you have used them. I have a radiant job where we need a direct vent product. I need the smallest "Delta-Elite", the F-25. (100,000 input)
What other good direct-vent oil-fired boilers do you use?
Thanks in advance,
Mike
Thanks in advance,
Mike
Has anyone used one?
Have one on order to try on a small house, but haven't installed one yet. Another contractor in town has done a couple and said it was a quick install. They are not as efficient as most oil fired boilers we install, (Buderus/Veissmann/EK), and are designed more like a water heater than a boiler, but I guess I will find out how they work, on a lower budget dhw/baseboard job. Won't be installing it until Jan. or so. Let me know what you think if you beat me to it.
Steve0 -
Laars Max
I've gotten good results with the Max boiler although I haven't used one since it was made by Trianco. It still looks the same. I believe the smallest size is 105,000. The 3 smallest sizes are actually the same boiler, you just use the correct nozzle and attach the matching sticker to the jacket. I strongly recommend the thermostatic union which controls the flow of water through the boiler to prevent condensing, especially if you're using the smallest nozzle size.
Tom M.
http://www.laars.com/oilfired.htm#MAX Boiler0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
