greenhouse boiler
john_27
Member Posts: 195
has anyone any recommendation on a greenhouse boiler...has to be able to survive in a humid climate...it will be connected to an old underbench heating system...John
greenhouse boiler
I think a Munchkin boiler would be great, Plastic outer case, inner components aluminum or stainless. Sounds fairly good match.0 -
Greenhouse
Munchkin or The new W-M ultra. The dunkirk Q90 has too many steel parts.
Mike0 -
Nothing!!!! better to build a small \"boiler room\".
John, I have done allot of service on "greenhouse" systems both air and water and have never found one that will really hold up, it would be cheaper in the long run ie: service,parts, loss of plants(income) to remove it a boiler room. P.S. dosen't take long for a greenhouse to get cold,real quick. So any thing you do to help avoid problems is money well spent. Hope this helps John@Reliable0 -
greenhouse boiler
i need 280 output...should i install two in tandem...or...a friend of mine likes viessman...overkill for this job/0 -
I'd vote
to mount the boiler outside of the humid enviroment also. Even if the jacket, etc is plastic or rust resistent.
Electrical components, motors, switches, modules, etc may not be happy in the "wet"
I think a Munchkin 399,000 is available. Plenty of condensing tank type water heaters available in that BTU range.
hot rod
Love the Veissmann Vitodens!!0 -
greenhouse boiler
spoke with someone today who feels that a condensing boiler isn't necessarily right because I have no drain or place to handle the condensate...remember this is an old gravity fed system...pit in the basement.etc..,,so ...where does the condensate go?0 -
To a condensate pump, or some manner of lift station. Could be a simple $100 or slightly more type.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
