Oventrop
Paul Rohrs
Member Posts: 357
I have been doing some hydronic designs that employ Outdoor reset and constant flow. I have been utilizing the Oventrop Unibox ET. Does anyone have any "drag-n-drop" type icons I can use for my Visio CAD program?
Last job had a 7200 sqft bay (single zone SOG) and then 8 offices each with their own temp and Unibox control. That secondary loop had a DPBV on it and direct return from each of the Unibox. It sports a Peerless Pinnacle boiler with a buffer tank. We used the buffer tank aquastat to the boiler TT to actuate off of temperature, rather that from an end-switch.
You can see where I will place the Oventrop Icons. (I may just create my own icon if nothing comes up.)
Regards,
PR
Regards,
PR
The only oventrop item I ever use is their nice little oil filter, so I'm not much help.
Steve0
