Antifreeze test kits
Al_12
Member Posts: 21
Does anyone know where i can find test strips or a kit to check the strength of cryotech antifeeze in a system. I went with the manufactuers ratio, but i would like to take a sample just for the hell of it.
is this what you want?
refractometer from misco is what i have:
http://www.misco.com/refractometer/handheld-refractometer.html --
and a ph meter:
http://electrical-contractor.net/The_Store/EX/WaterQuality_PH-ORP.htm0 -
How much info
and how accurate do you want to be. Thre simple strips should be available where you bought the "juice." If not contact the manufacture or rep.
Meters are more accurate. The meter listed above is my favorite. A PH meter would be another good investment for checking glycol every year. Graingers has them for around 80 bucks.
On the low tech side of testing, draw a small sample and put it in your freezer overnight, along with a thermometer!
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 129 Chimneys & Flues
