Onepipe Steam
Richard D._2
Member Posts: 156
Hello and thankyou for your help!
Today I found a cracked 7 y/o boiler . :( I think its piped wrong.Im not familar w/counter flo steam piping but common sense says WRONG!!!A pic will follow.(before and after)
It has 2 2 1/2"risers off the boiler. NO HEADER!1 riser goes to each loop!The equalizer line is on 1 main.The specs say 1 1/2" but they have 1 1/4".Header specs are 2 1/2"..Could this piping have caused sevaral cracks?I need more info on counter flo piping.The piping pic in Dans book shows feeding the header from the top.
( great book.I told the new guys to get it)Any proper pics you have would help.Im ordering the new boiler tomorrow. Should I join the drop header club with this system??:) Want to anyway.I have 2 off set mains coming off this job..Thanks Rich
Good ideas
Be sure to connect each main to the header with it's own tee.
I like the equalizer to be full size down to the hartford loop tee.
I like to look up the main size requirement for the whole output of the boiler, and increase one size, for the header; OR, use the manufacturers minimum size, which ever is bigger.
I like to find out what the A dimension will be before I start.
Noel0 -
This is
a 1 pipe counter flow system..With no returns.Sorry for lack of info..Thanks for your info,it will be used ..Rich0 -
Drip each supply
The driest way to connect the counterflow mains is to drip each supply.
Here, let me draw something. It'll take forever for me to figure out how to verbalize it.
Noel0 -
Thanks Noel BUT
I do not have a return pipe..Just the mains which is the heat and condensate return..Condensate drains thru equalizer line..But you piping looks great and from what I saw the header looks like the littlepec I sae of what I have..II draw what I have.may be using the wrong name for it.0 -
Thanks Noel BUT
Noel
Thanks for the pic its great.But I do not have a return on this job.The main is also the return.. and no hartford loop.Never saw a system piped this way.But they did not install a header and I think that is why the boiler cracked. Hoping to find some pics on this type system..Thanks Richard0 -
I know you don't
That's why I showed you what you need to do to make it work.
Noel0 -
Thanks Noel
for all the help...Rich0 -
follow
hi rich; follow noels advice and everything will work great. i know this because he has given me great advice more than once. allways correct. i have learned a lot from noel.
have fun with the counter job joe.g0 -
Thanks you
guys for the help.I want to do it right and want to join the drop header club
!! Win Win situation!!!Thanks again for all you help Rich..Will post a before and after pic when done... 0 -
Counterflow Steam System
The attachments are not to take away from anyone's expertise. The Hydronic Institute has a diagram of how a counter flow system near boiler piping should be install.0 -
Counter Flow
Here is a better image.0 -
Follow the Manuf. instructions on header and equalizer piping.
Beyond that, if you don't want to drop the return to the floor to keep steam out of it and to create a mudleg to catch and flush the heavy stuff that washes back to the boiler, fine.
But definately don't use that diagram instead of following manufacturers instructions.
Noel0 -
Waiting on
the manufacture for their specs..But I see something new to me and I have to find out as much as I can about it!!Yea one of those lol...I really want to say again HOW much I appreciate all the helpI recieved from you all..
HEY RS how can I get one of those manuals from the Hydronics Institute???It look great.. Richard0 -
Right here, with or without the course.
http://trainingroom.slantfin.com/courses.html
http://www.heatinghelp.com/shopcart/product.cfm?category=2-102
Noel
- 87.4K THE MAIN WALL
- 116 Geothermal
- 15.8K Strictly Steam
