Periodic Boiler Flushing
Tom_22
Member Posts: 108
Do you believe in flushing old oil fired boilers and one-pipe steam systems periodically or only if they specifically need it? Do you recommend it a certain minimum amount?
What symptoms will lead you to recommend or perform a flushing...spitting air valves, etc.? What chemicals, if any, do you like to use? Are there any you avoid?
Jake
Jake
Flushing hot water systems
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
