primary secondary
DKH
Member Posts: 15
Where can I find some scematic drawings of primary/secondary systems using the boiler as part of the primary?Any comments on the use of the boiler as part of the primary loop will also be appreciated Thank You
Plenty of books on the subject available at \"Books and More\"
Many of the boiler and radiant manufactures have drawings at their websites.
Still a good idea to know and understand the concept, not just coping a drawing. Sounds like that is what you are asking.
One concern with the boiler in the primary loop, is cold return temperatures. Not a problem with condensing boilers, but you need to watch for this on radiant and cast or copper boilers. You may want a thermostatic mix valve in the loop or a control that would drop secondaries till the primary catches up.
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
