flow meter manifold
Gary
Member Posts: 29
Whats the best flow meter manifold system out there now.? I use to use Wirsbo but they quit making the visual ones.
I know
that heatway/watts has visuals. WW
Check out
the Oventrop stainless, also. They have the largest flow indicators of any I have seen. Nicely formed stainless, and will accept a variety of zone heads. Nice gasketed sweat or threaded adapters. Up to 10 branches on one continous manifold, I believe.
hot rod
Wirsbo
Has the new Tru-flow manifolds,I've used a couple and like them very much.
For low temp?
If you need them for low temp applications, (<150*) RTI has a modular setup that I have used a lot of. Works good, you can assemble them by loop. I've put up to 17 in a row and had nice even flow through each. These also have a balance valve integral to the manifold block. Trade name is Thermo-Lock. These are 1 1/4" pipe size.0 -
Try this link
http://www.wirsbo.com/main.php?pm=1&mm=4&sm=6&pc=common/showroom/index.php&sroom=8
This is our new True Flow manifold. The electronic temperature and flow measurement is real nice.
Tim D.0 -
ThermalLock
Steve and all-
Here is the picture of the ThermalLock Manifold.
Line up tab A with slot B, give it an 1/8 turn and it is "locked"Dave Holdorf
Taco, Inc
Thanks Everyone
There are alot of great products out there , the reason I like the visual ones is you know exactly whats going on inside there and the customer loves it to when he can see whats going on.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
