Circulating Pump
Les_2
Les_2 Member Posts: 3
Mark was right...I had a ton of air in my system..once bled it was fine...thanks Mark.
  • Les_2
    Circulating Pump
    I have a three zone H/Water system and one of the circulators will run but no hot water is getting to the room that it services. Anyway that I can check to see if the pump is running properly. I can hear it run and see the shaft turning....but...no hot water...my other circulators are fine distributing water to the other zones...thanks.
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    It is rare...
    that the impeller falls off, but it has happened. I suspect air binding first.
    ME
  • Mark Eatherton1
    You're welcome (NM)
    ME
