Tankless water heater for radiant floor
Dan Peel
Dan Peel Member Posts: 431
Based on experience.
Instant water heaters require two things - low flow and high temperature differentials.
By incorporating a low temp buffer tank to show the instantaneous volume to raise the temperature of you can operate radiant reasonable effectively.
Without a buffer tank, or where high temperature emitters are employed they are a poor choice as a heating appliance.
IMHO..... Dan
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=174&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Rick_11
    Rick_11 Member Posts: 2
    Tankless heaters & Radiant
    Are there any opinions or experiences with using a tankless water heater for radiant heat supply. Shop is 32'x40', 6" slab, 1" ins under, 2" perimeter, 1/2" pex on 12" centers. I am considering an Aquastar 240fx Heater with LP gas.
