Boiler replacement
oilwizard
oilwizard Member Posts: 46
Just some pics of one of our recent jobs, befor and after.
Joe
    Steamhead Member Posts: 17,489
    Looks Good
    The Mills was one of the best boilers in its day. It will be interesting to see how much better the Buderus performs.
    Consulting
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    what did...
    they do for DHW before? How big is the new Alliance? It appears to be an old gravity system....did you prioritize the DHW zone? And is there some type of system by-pass at all? I realize the 215 can handle low return temp...just didn't know how low for how long. How many sections is the 215. Nice neat job! kpc
  • oilwizard
    By pass and such
    If this was a gravity, someone put a circ on it befor I came there, it had an old taco 110 on it. The house sized up for a 4 section buderus. The indirect is a 40 gallon, replaces a 30 gallon gas water heater. And yes, it is on a priority. There is a bypass loop, its tucked in behind the boiler. If you talk to a rep from Buderus, they claim the 215 don't need a bypass because of the internal pipeing and the silicon in the cast, but old habbits die hard and I hate to go back and redo something I just did. The best part abou this job, this was a solo project of about 2.5 days, except for getting the old boiler out, good thing there was no stairs.
    Joe
  • jim_14
    jim_14 Member Posts: 271
    is that an
    indirect hot water tank?
  • kevin coppinger_4
    Better to have....
    a bypass and not need it..... than to need a bypass and not have it....kpc
    PS> It is a 40 gallon indirect heater, Burnham alliance
  • Joe_30
    Joe_30 Member Posts: 85
    What is the grey device upper left of the water heater, a air inlet fan to the outside? brand?
  • Earthfire
    Earthfire Member Posts: 543
    electric
    Is that the power switch in that 4sq.box on the ceiling. Looks like the copper supply pipe is right against it. If it is as tight as it looks that kind of bends NEC disconnect accessability regs
